Reload this Page >
Pilot-rc PREDATOR 2.2m Sport jet / full composite
Old 03-23-2019, 09:24 AM
  #451
airborn900
My Feedback: (25)
Anyone know the capacity of the smoke tank?
Old 03-24-2019, 04:07 AM
  #452
dccatl
2 liters
Old 03-28-2019, 02:45 AM
  #453
laiqalih
Hi..
wings and stabs were developing gap with fuse and on inspection it revealed that all wing and stab holding clamps bots are loose on my predator 2.2m,, after 37flights.. I replaced all the bolts with 25mm length as pilot bolts are small, 20mm, and where not coming out of lock nuts. so when ever you have issue replace the bolts. second I replaced the washer to big one to have more contact area over ply.
Just an update.
Old 03-28-2019, 04:05 AM
  #454
shepga
Thanks for the update. Any problems with your wing tube?
Old 03-28-2019, 04:19 AM
  #455
laiqalih
tube is fine.. it's 2.5mm thick aluminium ..
Old 03-29-2019, 10:56 AM
  #456
MikePS
MikePS's Avatar
Originally Posted by bodywerks
He told me only about 3mm/1/8", if memory serves
Thanks..I have some dialed in, not sure if its that much or not.
Old 04-11-2019, 02:33 AM
  #457
airborn900
My Feedback: (25)
Originally Posted by blainer48
Did anyone have issues with the stabs fitting flush with the fuselage? My right horizontal stab has a gap at the back while the left fits perfectly. Both wings and everything else fits like it should just the one stab. I'll post a picture tomorrow.
I am assembling mine mine now and have the same thing. Was going to ask the same question.
what did you find out
Old 04-11-2019, 05:58 AM
  #458
DHC6
DHC6's Avatar
Mine also has some inconstant gaps on the stab. I used clear duct tape to seal the gaps. Over 100 flights and no problems. I figure this jet is much less expensive then others, so some inconsistencies can be expected. As long as they don’t compromise the flight characteristics and safety, I’m happy to accept them.
Old 04-11-2019, 06:44 AM
  #459
airborn900
My Feedback: (25)
Can you send a picture of your clear duct tape fix. I’m curios how much it effects the appearance of the airframe.
Old 04-11-2019, 09:49 AM
  #460
airborn900
My Feedback: (25)
Anyone got a good set of rates and expo settings to start with? Factory recommended rates good enough?
Old 04-11-2019, 10:17 AM
  #461
BarracudaHockey
BarracudaHockey's Avatar
That's such a personal feel thing. I'd set factory rates and adjust to taste.
Old 04-11-2019, 05:45 PM
  #462
DHC6
DHC6's Avatar
I am away from home until Sunday night, I should be able to post some pictures for you when I get home. However with the clear duck tape (essentially stronger/thicker clear packing tape) its nearly unnoticeable, especially if you take your time to make sure there’s no bubbles.
I used the recommended rates, and still do in fact. As someone stated, it’s all personal feel, but it’s a good stable place to start. I find it it could use a little more roll, but it makes for a nice smooth starting point.
Old 04-13-2019, 09:28 PM
  #463
tuan lam
tuan lam's Avatar
wow so many jet trainer
Old 04-14-2019, 11:25 PM
  #464
laiqalih
Hi,
My jet elevators are 3mm up trimmed , I had moved CG maximum backwards, shall I go for more?. I have fear of touchy elevators?
Old 04-15-2019, 03:12 AM
  #465
DHC6
DHC6's Avatar
Originally Posted by laiqalih
Hi,
I would judge it by how it flies inverted more then how much up trim is showing. My elevator looks to be 2-3mm up, however it doesn’t need much down input when inverted.
Old 04-17-2019, 07:13 AM
  #466
DHC6
DHC6's Avatar
Sorry for the delay, here are a few pictures with the tape sealing the gaps. It’s pretty hard to see that there’s tape on there. It’s a little more tricky on the bottom side, but not difficult.
Old 04-17-2019, 07:30 AM
  #467
RobbieDJ
OH! that is not cool at all. Have not put mine together yet but I will be pissed if this is the fit.
Old 04-17-2019, 03:15 PM
  #468
DHC6
DHC6's Avatar
As I’ve mentioned I think it’s important to consider the cost of this jet compared to its competitors. It’s FAR less then the competition, so this is to be expected. To demand perfection at this price level I think is unreasonable. This jet offers exceptional value and has excellent flight characteristics. These “defects” don’t affect the flight performance at all, and you can’t see those gaps when it’s flying.
Old 04-18-2019, 02:45 AM
  #469
airborn900
My Feedback: (25)
My fit is slightly better. But I need to be able to remove stabs for transport. I don’t think I will be able to tape them.
Old 04-18-2019, 07:10 AM
  #470
RobbieDJ
Duct tape on my custom paint job? "I don't think so Tim"; if I have to block sand them to true them then I will repaint the edges. AND "for the price" is not a qualifier for poor workmanship or design. Try that on full-scale and see what happens. JMHO
Old 04-18-2019, 07:47 AM
  #471
why_fly_high
My Feedback: (19)
Ummm, Comparing a mass produced cheapest price point composite toy to a full scale plane is completely irrelevant. Having working in the full scale composite aircraft world, there are some fluctuating gaps with all of them.
Old 04-18-2019, 01:31 PM
  #472
Agrav8ed
I have two composite Harlock Vipers the are made of Airex that have a perfect fit and almost flawless paint jobs. They are $629 new. I sent my predator back because of poor fitment and many, many flaws in the paint job. I would not compare out models to full scale quality but I do thing that quality matters and a little more attention to detail is warranted in a $2500 composite jet. Saying that it is at the lowest price is not really an excuse for poor workmanship.
Tone
Old 04-18-2019, 07:06 PM
  #473
RobbieDJ
Talking
Nonsense, good workmanship is good workmanship so I will reserve further commentary until I test fit mine. I am a full-scale pilot too so I have been around the patch plenty.
Old 04-19-2019, 05:48 AM
  #474
why_fly_high
My Feedback: (19)
You are correct. Good workmanship is good workmanship. At this price point and being a toy good workmanship is if it looks nice and stays together in the air and can take some abuse. Having perfect gaps and flawless paint is craftsmanship which is much less common and more expensive.
Old 04-19-2019, 10:14 AM
  #475
RobbieDJ
Well, I had to have my instant gratification so I unpacked the stabs and test fit them. They say a picture is worth a thousand words so here is my thousand. In summary, I would never duct tape anything on my planes that can be fixed with some time & talent.
Yours looks like a V1 with the removable rudder, correct?
