Reload this Page >
P-39 Airacobra Brotherhood
Old 03-20-2014, 03:12 PM
  #76
DavidAgar
My Feedback: (108)
DavidAgar's Avatar
Sign me up please. I have always loved the P-39. I have a red box Top Flite kit to build and I have a House of Balsa one as well. Thanks Dave
Old 03-20-2014, 07:26 PM
  #77
WARBIRDRCER
My Feedback: (22)
WARBIRDRCER's Avatar
P-39 Airacobra Brotherhood Update, we now have 27 in our squadron.
Welcome to the P-39 Airacobra Brotherhood
27. DavidAgar
Roster
Start Date: 02-14-2014
Current Date: 03-20-2014
Roster
1.Warbirdrcer
1.5 Talimena Kidd
2.RPRCBuilder
3. Maser
4. P51NUT
5. Bill Diedrich
6. TLH101
7. Warbird51
8. lightning 759
9. P-39 fan
10. Zero TX, USA
11. redtail VA, USA
12. jtotten IL, USA
13. stage1 IA, USA
14. Plano78 TX, USA
15. p-39 MN, USA
16. ByronF Canada
17. Iron Dog CA, USA
18. RZayas OH, USA
19. jkpape KY, USA
20. lkruse OK, USA
21. airboss45 NH, USA
22. hilgale KY, USA
23. Firepower R/C IL, USA
24. LarsL WI, USA
25. AZThud AZ, USA
26. Dweeb7944 MA, USA
27. DavidAgar WA, USA
If you would like to join the P-39 Airacobra Brotherhood please send me a PM, or ask by posting your request here. I will track and assign you a number.
Never can tell when you may run into another Airacobra Brother some where, so join now.
Old 03-26-2014, 10:15 AM
  #78
WARBIRDRCER
My Feedback: (22)
Can anyone tell me how much a TF Red Box P-39 Aeracobra is worth?
I know it most likely ranges based on want, but for the average person looking to build one, what would you say?
Old 03-26-2014, 11:49 AM
  #79
Zero
My Feedback: (42)
Zero's Avatar
I purchased one about 3 years ago for a friend for $100.00. Price is based upon how bad someone wants one.
Old 03-26-2014, 12:01 PM
  #80
jkpape
It's only worth as much as someone is willing to pay, not what someone is asking.
Old 04-26-2014, 04:08 PM
  #81
AZThud
Hello Fellow P-39 Aficionados
I have finished glassing and sanding my wing and am about to put down the panel lines, my drawings are pretty small and I am having some difficulty trying to figure out how far to put the two parallel lines apart. The line look to be where the spar is, my 1/72 scale drawing has them just under a 3/64th apart which when converted to 1/5th would have them about 0.675 apart. That would translate into just over 3 and third inches on the full scale. Does that should about right? Does anyone have some good drawings and can advise? Thanks
Cheers
Old 04-26-2014, 04:44 PM
  #82
TLH101
My Feedback: (90)
TLH101's Avatar
Pm me your e-mail and I will send a good pdf I have. Can't upload to RCU.
Old 04-26-2014, 05:07 PM
  #83
AZThud
Thanks, PM Sent
Cheers
Old 04-27-2014, 09:36 AM
  #84
shanksow
shanksow's Avatar
Originally Posted by WARBIRDRCER
Just pulled the canopy plug yesterday. Next on the to do list is to learn how to vacuum pull a canopy and we will be okay.
Looks good! I might like to get in on this. I am in the process of buying back my UN-completed Top Flite P-39 from the LHS. Missing the box full of goodies and plans and manual. But right now, I'm just trying to save the fuse and wing from getting trashed anymore than it has already. LHS just went through a ownership change and the new owners gave me a good price to get my model back so I took them up on it.
Old 04-28-2014, 07:45 PM
  #85
Iron Dog
Iron Dog's Avatar
WARBIRDRCER,
Did you pull a canopy already, or already get the help you needed? If not, PM me and I'll give you my phone number. I built my own vacuum forming machine (pictured being used in my "Trinity Build" thread linked in my initial response). While I'm no professional, I've made my initial mistakes and can at least save you some of the learning curve with this process, if no one with more experience else has helped you, yet.
Ollie
Old 04-29-2014, 01:07 PM
  #86
AZThud
With some help from the drawings that Terry sent me I put down some panel lines on the bottom of the wings. Things are not exactly to scale, but they do look to be in the ball park. The leading edge intakes for the radiator and oil coolers are a bit to far from center, but the shape of the wing dictated the placement. All in all it looks to be an improvement from the original ESM wing.
These were taken after I wet sanded the primer down to the tape, I used 1/32 as it is pretty close to the lines on the fuse. The big gaping hole is where the speakers will be located. I have grating that fills in most of the whole, after final paint, markings and some weathering, they will be less visable, I hope :-)
Name:	Panel Lines1a.JPG
ID:	1991166   Click image for larger version
Name:	Panel Lines2a.JPG
ID:	1991167   Click image for larger version
Name:	Panel Lines3a.JPG
Old 04-29-2014, 02:17 PM
  #87
airboss45
airboss45's Avatar
Rick, what brand primer do you like to use for sanding off? also do you have a supplier[ website] for 1/32" chart tape. i can not find it here [ N.H.] locally at all. don
Old 04-29-2014, 02:28 PM
  #88
AZThud
The primer is Duplicolor High Fill Primer, I get it from O'Reilly Autoparts. Regarding the tape, I got mine from Amazon, a couple of years ago, I got an Amazon Prime account and its shocked me how much I use it. I think I got the one for 1.85 black, I ordered 4 rolls of the 1/64 and 4 of the 1/32. Whoever put the rolls in the envelope rolls wasn't that careful, as I got 6 and 5 respectively :-)
Link to the tape:
http://www.amazon.com/s/ref=nb_sb_ss...ar%2Caps%2C285
Cheers
Old 05-01-2014, 04:55 AM
  #89
WARBIRDRCER
My Feedback: (22)
P-39 Airacobra Brotherhood Update, we now have 28 in our squadron.
28. shanksow
Roster
Current Date: 05-01-2014
Roster
1.Warbirdrcer
1.5 Talimena Kidd
2.RPRCBuilder
3. Maser
4. P51NUT
5. Bill Diedrich
6. TLH101
7. Warbird51
8. lightning 759
9. P-39 fan
10. Zero TX, USA
11. redtail VA, USA
12. jtotten IL, USA
13. stage1 IA, USA
14. Plano78 TX, USA
15. p-39 MN, USA
16. ByronF Canada
18. RZayas OH, USA
19. jkpape KY, USA
20. lkruse OK, USA
22. hilgale KY, USA
24. LarsL WI, USA
25. AZThud AZ, USA
28. shanksow
Old 05-08-2014, 08:01 AM
  #90
WARBIRDRCER
My Feedback: (22)
Here is a brief update on the progress of our P-39s.
Old 05-11-2014, 12:21 PM
  #91
shanksow
shanksow's Avatar
Well, I officially paid for my P-39 and got it back from the hobby shop yesterday. Nose ring aft to firewallis broken off and lost. Wingtip is also gone. Still have the Robart LG main retracts and the Nosegear retract strut still in the fuse.
Old 05-11-2014, 03:06 PM
  #92
airboss45
airboss45's Avatar
Don28, good for you. you can always make her better than before. and she's yours now! don 21
Old 06-11-2014, 07:08 PM
  #93
WARBIRDRCER
My Feedback: (22)
Update: RPRCBuilder has completed the ready to cover construction of one of the P-39s. Now it is up to me to cover and finish for flight. All radio equipment is installed. We went with a fixed gear and flaps for the young flyers in our squadron, and a 10cc Evolution gas engine.
Old 06-12-2014, 01:13 AM
  #94
Kurppi
Hi All,
Please add me to the list.
I have been building a Top Flite GE kit for ... so many years With very limited time and lots of ambitious modifications it takes a lot of time, however it is an joyful voyage...
I have modified the rudder hinge line, bottom half of aft fuselage (made it more rounded) wing fillets, ailerons, and most important nose section. I had molded the complete nose section and produced fiberglass parts for cowl and front landing gear compartment and doors for LG.
I also molded the rudder and elevator (with scale hinge lines). Also 12 stack exhaust stubs are molded and made from resin. I will use a RCV 90 SP and the bird will be finished as COBRA II racer... I actually have a build thread in RCSB if anyone is interested.
WARBIRDRCER, I see that you made a plug and Vac-form new canopies, are you planning to sell canopies? if so I am interested to get one as my canopy was ruined at the time I get my kit, and TF does not have any replacements... I had started to make a fiberglass mold for the frame and was planning to make the canopy with clear sheets glued to this fiberglass frame, but if it is available one piece vac-formed canopy would be much better...
Here are a few photos of my bird at current state...
Overall primed view:
Nose section:
Front Landing Gear Doors:
Rudder Mold:
Exhausts:
I do not have the elevator mold photo yet, I'll add it later.
Regards,
Evren
Old 06-12-2014, 01:39 AM
  #95
airboss45
airboss45's Avatar
Kurppi, very nice work. it looks really scale on the mods. love all your work. we all thank you for posting the work pictures. don
Old 06-12-2014, 03:28 AM
  #96
Kurppi
Thanks Don,
Looks much better than the original but I have learned my lesson well... If you want scale, build from a scale plan or scratch It is much harder to modify a kit to look "more" scale...
Evren
Old 06-12-2014, 04:07 AM
  #97
jsjshjshu
If you get some good pulls, and want to sell some, I would be interested in purchasing one.
Old 06-12-2014, 06:02 AM
  #98
bigbird007
bigbird007's Avatar
sign me up too, I have a TF gold edition done up in the Brooklyn Bum II color
Old 06-13-2014, 03:35 AM
  #99
yel914
yel914's Avatar
I'd like to be signed up as well. I have 2 yellow box kits, 1 red box kit, and a GE plan set. I haven't built any of them yet, but I'm gearing up. With so many P-39s, I thought it might be a good idea to make some extra cockpit kits for them. I started with an original TF Airacobra kit but was very disappointed with the parts they supplied, so I'm making my own molds and ther****rming new parts. Top Flite really took some liberties with that cockpit kit. They brought stand off scale to a new low. Anyway, please sign me up.
Old 06-23-2014, 09:45 AM
  #100
skyarrow1
Please add me to the Brotherhood... have the ESM P-39. Also, need to know where I can get a replacement canopy???
Mike
