Reload this Page >
ESM Dornier DO 335
ESM Dornier DO 335
Old 07-14-2016, 12:49 PM
  #801
snauwaertj
Auch!! Why did he pull this bird so hard?
The Kit is from Andreas Engel from Modellbau Engel, it is currently not available because he is reworking to have a full gfk wing. The older kits have styro-abache wings.
It is way bigger and has the value of 4 ESM do's. The ESM is perfect size for me, it might just fit in my car.
I see the original ESM landing gear is version 4 now:
http://www.bigplanes.nl/contents/nl/...rplane-G4.html
Would this be recomandable or still no good?
Old 07-15-2016, 09:18 AM
  #802
skubacb
skubacb's Avatar
I would love to see how version 4 is going. All the versions prior (as I have heard) wound up stripping the gears. Anyone out there using them and for how long?
Everyone uses the surge the electrical system sees when the gear hits the end. Some just leave it there and this puts quite a strain on the gears. I know the Electron gear slightly back-off thus releasing all the tension. With the v3 some people put a rubber bumper at the end of travel so there was less stress. This made them last longer but they failed.
I would love to see someone setup a system to stop prior to hitting the end. Maybe an IR sensor or they could allow it to be setup counting the turns of the motor. Unless someone does that your gears will always need to be stronger than necessary just to bring up the gear.
Old 07-22-2016, 04:44 AM
  #803
snauwaertj
Finally today she arrived, never had so much plane for my €€€€.
and she looks great and solid. Only the inside looks like it has been assembeled by a monky, but I don't care about that because I will have to change everything to fit my special setup.
I'm a very happy person :-)
ID:	2173954   Click image for larger version
Old 07-27-2016, 10:37 AM
  #804
snauwaertj
Does anybody here have a crashed Do335 for parts?
My brand new box is missing the bottomhatch @ the back.
Tried to contact both ESM and the shop where I bought it, but no reply.
If someone would have this part I would gladly buy it.
Regards Johan
Old 08-04-2016, 12:20 PM
  #805
snauwaertj
ESM will make the piece that was missing in the box ans ship it to me for free!
great service!
Old 08-04-2016, 12:49 PM
  #806
snauwaertj
The last days I started on the tail section.
I had to cut in the original bulkheads to make space for the jet pipe, I also had to cut away the centerpiece of both the tubes. To keep the rigidity intact I had to do a lot of reinforcing, but she is defenetly as strong as she was before.
ID:	2175771   Click image for larger version
ID:	2175772   Click image for larger version
Old 08-04-2016, 12:57 PM
  #807
Ram-bro
My Feedback: (101)
Nice going. You got my attention. 2 questions, will the carb intakes be functional and are you drawing air in for the turbine from the radiator intake?
Old 08-04-2016, 01:17 PM
  #808
snauwaertj
I have ordered the flitemetal I want to use to cover the upperside of the plane with today, when it arrives I will give it a try on the big hatch behind the canopy. If this works out, and I am sure I can do the whole plane, I will cut away the back carb intake and close the back scale exhausts. The front carb intake will be opened, not to give air to the turbine who can thake plenty of air from the big cut out for the nosewheel, but to cool the jet pipe as much as possible. The same goes for the radiator inthake.
At the back end, behind the tail I wil make 2 square openings under the jetpipe to let the air out that can not pass the holes around the jetpipe.
Old 08-04-2016, 01:23 PM
  #809
snauwaertj
Maybe I will put the intakes from,the early prototype on his back, not sure yet.
Old 08-05-2016, 03:18 AM
  #810
snauwaertj
Jet engine found it's place :-)
Old 08-05-2016, 04:56 AM
  #811
Ram-bro
My Feedback: (101)
When I needed to order some scale accessories for my 335, like the exhaust sacks and carb intakes, I went to IMP Scale and ordered them. They were from their D9 and Ta 152 kit lines. They came out pretty nice. Glad to see the turbine fits.
Old 08-07-2016, 12:07 PM
  #812
snauwaertj
Breaking my head wich retracts to buy.
Really like the electrons, but I want brakes and elektric brakes are no good. So if I need air for the brakes I can use pneumatic retracts anyway.
I see Sierra and Robart make complete sets without the wheels, what size of wheels can I use If I would buy one of these. I see Robart makes electric retracts now, that seem to be no good I read in some reviews. If asked, would they still make them pneumatic?
Old 08-08-2016, 06:45 AM
  #813
Joespeeder
Hi snauwaertj,
Following along and enjoying your build !! The Electron Brakes seem very impressive. Why don't you care for electric brakes?
https://www.electron-retracts.com/wheels-brakes/
Have had failures with electric brakes previously?
Joe
Old 08-08-2016, 11:57 AM
  #814
snauwaertj
Hello Joe, 2 friends of me have electric brakes on their avanti Jets.
the braking power is less than 50% compared to pneumatic ones.
And even if I wanted to use elektrics, they only go up to 100mm, I need 130mm.
Another problem would be the legs, I have looked around and I can not find anything usable.
Johan
Old 08-09-2016, 06:05 AM
  #815
Joespeeder
Thanks Johan,
I've never played with or even seen braking systems other than when looking at various retract systems web sites. Interesting.
Electrons gyro guided differential system looks really cool but I have no real feel for what is good, needed, or usable when it comes to brakes.
Keep up the photos, I'm watching and learning !!
Joe
Old 08-12-2016, 01:15 PM
  #816
snauwaertj
Started applying the flitemetal on the hatch behind the canopy, 2 houres later I did half the hatch.
Its hard work putting a plane in this aluminium!
ID:	2176677   Click image for larger version
Old 08-23-2016, 12:02 PM
  #817
snauwaertj
Very, very slowly making progress:
I have ordered the Robart retracts, complete with the braked aluminium scale wheels, I hope I wil not regret it later on.
Old 08-26-2016, 11:24 AM
  #818
snauwaertj
One wing fully plated
Old 08-27-2016, 06:13 AM
  #819
snauwaertj
Don't know if anyone even looks @ this thread, but here is my progress:
removed the back air inthake scoop and closed the back exhausts.
ID:	2178418   Click image for larger version
Old 08-27-2016, 10:24 AM
  #820
Ram-bro
My Feedback: (101)
I am still lurking. Watching videos last night, , thought I saw a 435 on the flight line. It was a European rc show. Cant rememeber which video it was.
Old 08-27-2016, 02:12 PM
  #821
jimkron
I also interested. This will be monumental if you can pull it off.
Old 09-03-2016, 03:52 AM
  #822
snauwaertj
Thank you guys, would love to see that video Ram-bro.
The last days I have been working on the fuselage. Made the cut out for the 35cc NGH rear exhaust, this engine sticks out only a little bit and the exhaust system stays inside completly. The Krumscheid 4 chamber cannister with all the neccesary tubing also arrived.
I cutted out a big hatch @ the bottomside behind the engine to give me some workingspace for the cannister, the ignition and the choke-throtle servos.
Arount the back dummy-exhausts there was a litlle square part standing up around them. Because there are no more back exhausts I wanted this removed to have a nice flat panel. When I started grinding this I noticed I was weakening the fuselage a lot. So to give it more strength again I laminated a piece of 200gram Carbon over the hole length off the fuselage inside, a piece off 6mm depron on top off this and then again some Carbon. The backsides are like concrete now.
ID:	2179351   Click image for larger version
Old 09-11-2016, 06:22 AM
  #823
Katniss
Katniss's Avatar
Been away from the thread awhile....interesting progress mounting a turbine in the tail!
Old 11-27-2016, 11:38 AM
  #824
snauwaertj
Finally after 2 thimes being delayed the Robart retracts arrived.
Looking good and with pneumatic brakes!
ID:	2191441   Click image for larger version
Old 11-28-2016, 08:56 AM
  #825
Mr DJ
Johan
Just now seeing your posting of the DO 435 – Sweet!
I had the same idea since 2011; told ONLY one RCU member: Jimkron. Jim, thanks for keeping my secret a secret Jim and I finally met up at Warbirds Over Delaware 2011; good man and almost as Kool as me .
I had planned to debut my Secret Weapon: DO 535 (not 435) in 2012 but for medical reasons I did not. In post #359 I stated with photos that my front engine was going to be a DLE 55 and a Syssa 30 in the rear. In post #360, Jim jokingly said “Hmm...something does not look right on Mr. DJ's rear.” That’s because he knew a turbine would be the rear engine and that I was just tricking everyone until I debuted it. Now that you, Johan are creating one, I may get re-excited and finish mine.
Nonetheless, let me Congratulate you on your project; can’t wait to see her fly. And if I can assist somehow, just hit me.
Mr DJ
Name:	Mr DJ DO 535 2.jpg
ID:	2191552   Click image for larger version
Name:	Mr DJ DO 535 3.jpg
ID:	2191553   Click image for larger version
Name:	Mr DJ DO 535 4.jpg
ID:	2191554   Click image for larger version
Name:	Mr DJ DO 535 5.jpg
ID:	2191555   Click image for larger version
Name:	Mr DJ DO 535 6.jpg
ID:	2191556   Click image for larger version
Name:	Mr DJ DO 535 7.jpg
ID:	2191557   Click image for larger version
Name:	Mr DJ DO 535 8.jpg
ID:	2191558   Click image for larger version
Name:	Mr DJ DO 535 9.jpg
Name:	Mr DJ DO 535.jpg
