Reload this Page >
Buying wing connectors in bulk
Old 02-25-2024, 03:54 PM
acw
Default Buying wing connectors in bulk
If you are like me, you usually build your jets with a single connector for the servos, retract and brakes. Various hobby sources are selling these connectors under various brand names and for like 10 to 20x or more what they are actually worth when purchased in bulk. Further the number of terminals provided is the exact count so usually it is needed to buy some spares.
Over the last few weeks I spent a few hours to research how to get these connectors in bulk. I thought I would share with this community with the hope that someone will find it helpful. The links are for Digikey. I have no affiliation with them. They just offered the best search feature and let consumers buy at bulk price in pretty much any quantity.
When bought in bulk, you need to buy the plastic plug, the plastic receptacle as well as the male and female compatible terminals.
So called "ashlok" connectors
10 way:
https://www.digikey.com/en/products/...1070009/210976
https://www.digikey.com/en/products/...0579410/115050
4 way:
https://www.digikey.com/en/products/...0579404/115057
https://www.digikey.com/en/products/...1070003/210970
terminals:
https://www.digikey.com/en/products/...6020115/171959
https://www.digikey.com/en/products/...021124/1656203
Higher amps connectors in 10 ways sold by brands such as hacker
https://www.digikey.com/en/products/...78802-8/664284
https://www.digikey.com/en/products/...78288-8/664187
terminals:
https://www.digikey.com/en/products/...75218-2/659437
https://www.digikey.com/en/products/...75289-2/659456
Hope this helps!
Old 02-25-2024, 05:04 PM
camss69
My Feedback: (46)
camss69's Avatar
Awesome!! Thanks!!!!
What did you use for filters to find the amp connectors? Would like to be able to find the other sizes like 12 pin for running lights in the wings as well. 20 plus pin for single wing connections etc..
Old 02-25-2024, 06:34 PM
acw
There you go:
https://www.digikey.com/en/products/...SQGBWMAEzUaIoA
Old 02-25-2024, 10:57 PM
camss69
My Feedback: (46)
camss69's Avatar
Originally Posted by acw
Thank you!
Old 02-27-2024, 07:05 PM
sirrom
Dude what these resellers charge
Skunkwrks (03-02-2024)
Old 02-28-2024, 07:30 AM
jvaliensi
My favorite connectors are the Amp D3000 series. They are available from 4-pin to 20-pin.
Here is a copy of a recent order from Digi-Key. Finding the right part numbers is the hardest part, there are so many variations for each piece.
A29434-ND
CONN RCPT HSG 12POS 3.81MM
10 0 1.39100 $13.91
A29535-ND
CONN PLUG HSG 12POS 3.81MM
10 0 2.49900 $24.99
A29248-ND
CONN PIN 20-24AWG CRIMP GOLD
100 0 0.38630 $38.63
A29220-ND
CONN SOCKET 20-24AWG CRIMP GOLD
Auburn02 (02-29-2024)
Old 03-01-2024, 08:52 AM
CobraJet
CobraJet's Avatar
Amp D-3 series....same ones I've been using for awhile. They can handle the current draw, and repeated connect/disconnect cycles.
Old 03-01-2024, 10:09 AM
jvaliensi
I like the D-3000 series because they are easy to handle and make a positive 'click' when connected.
Old 03-01-2024, 11:49 AM
Afterburners
Afterburners's Avatar
I've been buying them from Hansen Hobbies. Pretty good prices as well.
https://hansenhobbies.com/products/c...pt1in_lp_1x10/
Old 03-02-2024, 01:24 PM
Skunkwrks
Skunkwrks's Avatar
Attachment 2273917 178289-6
A29434-ND
10 0 1.39100 $13.91
Attachment 2273918 178803-6
A29535-ND
10 0 2.49900 $24.99
Attachment 2273919 175288-2
A29248-ND
Attachment 2273920 175217-2
A29220-ND
Do you use any powerbox wire 20awg with these connectors ?
Old 03-03-2024, 05:49 AM
jvaliensi
I have used Powerbox wire with the D-3000 connectors. They will crimp down to 24AWG. Powerbox wire is non-standard size, it's not a common AWG or Metric size. It's about 21AWG but with smaller diameter insulation. Not my favorite wire.
Old 03-06-2024, 07:40 AM
Westwindpilot86
Posts like this need to be a STICKY thread kept at the top. Thank you for doing the research and finding these things.
camss69 (03-06-2024)
Old 03-06-2024, 02:03 PM
invertmast
My Feedback: (23)
invertmast's Avatar
Now where can we find servo wiring in bulk that is cheaper than the rc places? Lol
Old 03-06-2024, 06:51 PM
acw
There are many sources for wires. For example, I like this one: https://www.robotshop.com/products/s...hoC9OgQAvD_BwE
There might be better / cheaper alternatives out there.
For JR connectors (typical servo connectors), I buy them from Amazon...
Old 03-07-2024, 06:57 PM
CobraJet
CobraJet's Avatar
The Muldental wire seems to work well but very hard to find in the USA. I have a contact in Europe (Marek), the SU-30 builder, that will ship me spools. If you have friends in Europe, maybe barter with them?
Muldental Example site
Old 03-14-2024, 10:27 AM
F86_SABRE
From where can one buy 20AWG Futaba Silicone wire? Preferably from Europe as that is where I am located, however, all options are considered.
Thanks.
Reuben
Old 03-14-2024, 10:42 AM
CobraJet
CobraJet's Avatar
Like this? Muldental silicone Futaba cable
Old 03-14-2024, 11:12 AM
F86_SABRE
Yes thanks! In fact I managed to locate them in Germany and will be contacting them later on today. Hopefully they will also be able to supply loose (male & female) Futaba plugs (with gold contacts) as well.
Many thanks for taking the time to reply. Much appreciated!
Reuben
Old 03-14-2024, 11:21 AM
CobraJet
CobraJet's Avatar
Great news! I did mention the Muldental wire in the post above you but you may have missed it. Good luck and happy crimping!
Old 03-18-2024, 10:26 AM
AEROSHELDON
My Feedback: (99)
AEROSHELDON's Avatar
I saw a post where Danny from AeroPanda puts a small shrink tube over the servo wire and then crimps that on the AMP connectors. These are my preferred connectors and I will be using his idea going forward.
Old 04-22-2024, 05:11 AM
camss69
My Feedback: (46)
camss69's Avatar
Anybody know where to get the amp crimper at a decent price?
Old 04-22-2024, 06:04 AM
AEROSHELDON
My Feedback: (99)
I use the Powerbox one. YMMV
Old 04-22-2024, 06:19 AM
jvaliensi
I found the ICrimp tools from Amazon to work excellent. For the price they are well worth it. They work for servo connectors (Dupont 2.54) and the AMP D3000 series.
iCrimp SN-28B Dupont Crimping Tool
iCrimp SN-2549
camss69 (04-22-2024)
