CARF Rebel MAX - Build Thread
#226
Yes, I'll definitely pay attention to that but I'm not worried. If you do the same thing, just make sure you don't tighten the lock nut too much where you'd start binding the servo any. I know you're a great builder so I'm just preaching to the choir here but just make sure you have threads on the backside of the nut. Also, I've done a little research and tests and I would not use Loctite on these either. I've found that Loctite will sometimes eat the nylon/plastic bits in the lock nut.
AEROSHELDON (06-01-2022)
#227
Either way the pin/screw needs grease. That will stop the wear.
I’ve been using the pin clevis and C clip type for years and I’ve never lost a clip. I do consider which side I have the clip and try and protect it with the horn etc. Also I have had C clips I’ve discarded from new because they did not ‘click’ in position as I would like.
Lastly the black clips are a little harder material than the silver ones.
#229
Grease. Oil won’t work as well.
As long as the bolt is a good fit no problem using that as a 100% secure set up. I did it on something a long time back using a Miniature Aircraft USA shanked screw they had made for their washout unit (I can’t remember why I didn’t use the pin supplied on that one)
Dave
Dave
#230
My Feedback: (86)
I like the pins but did not like the C Clips so much, since they seem too soft. I was thinking to do the same thing: replace the pins with 3mm screws, washers and lock nuts. But, putting the "black C Clips" on, I would feel better about the setup, long term. If I have C Clips in my shop that fit, I'll go that route. If not, will change them out. Your posts have confirmed my concerns and thoughts as I finished up wings and tail.
Thanks gentlemen!
Thanks gentlemen!
#232
Sheldon,
No sir. It was a great fit, albeit tight, with the ER50 nose gear but it didn't require any rework. Hardest part for me was getting the bolts and lock nuts in there. I didn't attempt the blind nuts because the blind nut would have had to be ground down to clear the retract properly.
#233
My Feedback: (99)
Sheldon,
#234
My Feedback: (86)
did you guys have to widen the nose retract cutout? "If" I can get it perfect on the top to mark holes, there is not even enough room to allow the strut to turn. Really having a bit of a time lining this thing up to drill the holes. This might be a two person job....
And I did go with the provided Blind Nuts. They had just a hair of overhang past the plates and just ground them to flush with a Dremell.
Rb
#238
My Feedback: (86)
When I began to work on the nose gear, there was zero room for error on the gear to retract. Actually the strut didn’t really clear each side. The laser was a good tool again for this exercise, as the formers do tend to not be perfectly set, which can create an illusion issue.
#239
I have to crave out some fibreglass on my Viper to get clearance for the strut.
If the opening for the gear is tight use the Dremel to cut a couple of mm on each side for those ER50 gear.
#242
For me, that's correct. IMHO, you should always measure from the most effective point on any control surface. If you set up the CG 10-20mm aft of the spar tube, put in about 30-40% Expo on your elevator. You can tweak it from there.
AEROSHELDON (06-07-2022)
#244
You can use "Amazing Goop". I used "Goop Max". It makes it easy to take off and put on if you need to. Currently, I have mine off to get a little more throw. Silicone also works
#246
CG - I have mine at 20mm behind the wing spar at present. With the recommended throw, you have a lot of elevator so set up a D/R for a little less and stick in some expo (like 40%). Ailerons aren't bad at full throw. Be prepared to keep the power in it with full flaps. She basically stops in the air. I was flying 7-7:30 minutes and still had a little over 1/3 tank using the 5L supplied tank. I think a great place to start is probably 10-15mm aft of the spar tube. You can watch the first two flights if you haven't seen them already on YouTube.
smcharg (06-14-2022)
smcharg (06-20-2022)
