New turbine X 45 ,by Gaspar
#151
I just noticed my question did not come through on my previous post.
I am having trouble with Spektrum Telemetry. My receiver recognizes there is telemetry attached and it appears to be set up on the ECU however I don't get any turbine data back to the transmitter. I did the advanced setup and saved the settings. One from the latest firmware on my transmitter (does have turbine instead of Jetcat) and not sure what version on the receiver. Any suggestions of what to try next?
#153
My Feedback: (44)
Question for those of you lucky enough to have one of these in your possession
I need to find out the Center Of Gravity of the turbine with FOD screen installed, if you have a X45 that is not installed that you can check it would be appreciated.
Basically a simple way to determine would be to take a ruler (straight edge) and stand on its edge, then take the turbine and try to get it to balance laterally, the measurement from that point to the end of the exhaust cone is what I am looking for.
Now you may ask why do I want this....
I am making a fixture to be used for setting up my CG of my plane and I don't have the turbine yet, so this will be used to simulate the turbine installed.
#154
#158
For me, that X45 CG is looking to be 71mm from the tail cone end, with the FOD screen on. Right where the 2nd empty mounting hole (from the front) is.
I know it sounds kinda weird that adding the FOD seems to be going the opposite way of what Gaspar posted w/o FOD, I double checked twice more to be sure before posting this. Hope this helps. Mine does not have the latest elbow connector, is the straight connector version.
#159
My Feedback: (44)
Thank you for taking the time to measure it.
grbaker (12-07-2020)
#172
Not from US but very light with a clever install set from Sweden
https://www.hab.se/bygghobby/hab-cnc...t-komplett-x45
email [email protected]
#173
Not from the USA but from Australia.
I manufacture these pipes with or without Grumania Bellmouth.
This one is for Mini Avanti and Dual Wall with Small Bellmouth Entry.
Mounting tabs included.
Email Contact via Jet Products Australia website is best.
