Reload this Page >
Powerbox Core radio and set up thread.
Old 11-12-2019, 11:24 AM
  #176
AEROSHELDON
My Feedback: (99)
AEROSHELDON's Avatar
Yes, a 12 or 14 channel standalone rx is needed, with the ability to plug the gyro into it.
Old 11-12-2019, 12:03 PM
  #177
patrnflyr
My Feedback: (7)
patrnflyr's Avatar
Agree 100% with the above. I’ve looked very closely at this radio but it goes from a simple 9 channel to these huge powerbox units allowing dozens of servos, etc. A simple 12-16 channel would be nice.
Old 11-12-2019, 12:35 PM
  #178
Dave Wilshere
Just use the PowerExpander, Rx size, add any of the BUS Rx’s on any length of patch lead to get a good RX placement.
Anyway the future is the Mercury, everything in one box, small enough for any sport just like my Joker, Gyro, 15 channels-freely assignable, twin regulators, 5.9 or 7.4v output ( you chose) twin power input, twin Rx redundancy, a box of safety.
Old 11-12-2019, 12:46 PM
  #179
BarracudaHockey
BarracudaHockey's Avatar
I agree a 12 channel would be nice.
But it does NOT go from 9 channels to needing a Mercury.
Old 11-12-2019, 01:16 PM
  #180
Springbok Flyer
Springbok Flyer's Avatar
I agree with the reasoning for 12 and 16 channel receivers in the range. Personally I use many of the usual PB units (including the small but yet cumbersome, Expander) and still have a number of models where these are simply not the answer. Whilst PB has created fantastic new options, they do need to recognise the fact that it will need to replace existing installations in many cases - so please PB, make it a little easier for longstanding modellers to make the switch.
JanR
Old 11-12-2019, 01:28 PM
  #181
patrnflyr
My Feedback: (7)
patrnflyr's Avatar
Show me the product then... maybe i'm missing it
Old 11-12-2019, 01:56 PM
  #182
BarracudaHockey
2 x 9 channel rx, gives you channels 1-18 w/o needing a Mercury
Old 11-12-2019, 02:01 PM
  #183
Dave Wilshere
So my customers going from JR took out an 11ch Rx, A Sensor switch ( or Gemini II) and an iGyro 3e and fitted one neat Mercury...it really could not be easier. ( yes you have to connect 26D’s to it.)
I know the US market is different from Europe, but over here PB units are very very common
Old 11-12-2019, 02:02 PM
  #184
Dave Wilshere
How are you powering these Rx’s? Gyro?
Old 11-12-2019, 02:06 PM
  #185
BarracudaHockey
Batteries? LOL
What are you asking? Just like any other receiver where you need to plug up a battery, Y it with a non-critical channel.
Or use a channel slot on each.
Or use 2 channel slots on each, that still gives you 14 channels, 2 battery inputs, and plenty of channels.
Personally I think if you need that many you probably should be looking at power distribution anyways but if the question is, can it be done, then the answer is yes.
Old 11-12-2019, 02:19 PM
  #186
Dave Wilshere
Whether you would use Ni batteries, regulators etc, what batteries?
Old 11-12-2019, 02:27 PM
  #187
AEROSHELDON
My Feedback: (99)
Is there any issues using a Y-cable as an output into the 26ch rx with telemetry and Mercury input?
Old 11-12-2019, 02:34 PM
  #188
Dave Wilshere
Please explain... You using M link or Pbus2?
Old 11-12-2019, 03:01 PM
  #189
AEROSHELDON
My Feedback: (99)
P2Bus from rx, y into a turbine telemetry unit and Mercury for rx input.
Old 11-12-2019, 03:13 PM
  #190
BarracudaHockey
I gave up Ni batteries for lent.
I'd either use a regulated 2S, unregulated 2S, or A123 packs depending on the servos in use and the model I was setting up.
I want to qualify my answer again, I think a 12 channel would be great, any more than that you probably should be looking at a Mercury or similar and a couple of 26D receivers.
Old 11-12-2019, 04:25 PM
  #191
Growler84
My Feedback: (8)
Growler84's Avatar
All of the buss capable PowerBox receivers from the 5 ch to the 26 ch will push 26 channels in buss mode.
So, a Power Expander (18 ch output) for $129 and any of the buss receivers from $60 to $129 will give you 18 channels for $189 to $258.
I remember paying $200 for the older Spektrum 12 ch PowerSafe receivers for comparison.
I fly a JR12X, but I'm doing research...
Old 11-12-2019, 10:08 PM
  #192
Dave Wilshere
Should be fine, I presume the Mercury with latest update will have the drivers. Which turbine TELE unit?
Old 11-13-2019, 01:34 AM
  #193
David Gladwin
David Gladwin's Avatar
JanR
Having converted two models to Core, a little Savex L 39 and a much bigger Reaction both with just the 9 channel receivers conversion was simplicity itself.
Next will be an Airworld Hawk, 26 channel rx plus Mercury and I gyro. Hardly difficult. !
That said, perhaps PB will integrate these units into one unit as was done on the brilliant Weatronics Gizmo receiver.
Old 11-13-2019, 05:58 AM
  #194
AEROSHELDON
My Feedback: (99)
VSpeak unit.
Old 11-13-2019, 12:32 PM
  #195
BarracudaHockey
So I talked to Powerbox today and learned something new!
This
https://powerbox-americas.com/collec...13599091589184
Allows you to use 1 or 2 26D receivers placed for signal diversity and get full 18 channels and its available with deans or MPX input. For those installations that need more channels yet don't quite require a full Powerbox system.
Old 11-13-2019, 12:53 PM
  #196
Dave Wilshere
You don’t have to power the Expander through the MPX or Deans socket, all the positives and negatives are linked, so you can use the Sensor Switch or Gemini II std leads into spare sockets-just like an Rx
Old 11-13-2019, 01:01 PM
  #197
Bob_B
Bob_B's Avatar
I like what I'm reading!
Old 11-13-2019, 02:20 PM
  #198
Dave Wilshere
Expander has been around years. We use them on JR DMSS for more channels. Being SRS you have to set the radio type before it will work ( unless you are Futaba)
Old 11-13-2019, 03:53 PM
  #199
BarracudaHockey
Yes, tbh I forgot about it. When I was talking to them today Danny reminded me that this is another way to accomplish the mid-size models
Old 11-13-2019, 10:23 PM
  #200
Springbok Flyer
But it still mean that to replace my single 14/18ch sb Rx, that I need at least 1 x PB Rx + 1 x PB Expander or alternatively 2 x PB Rx's.
Please PB, give us a 12 to 16 channel Rx.
JanR
