Reload this Page >
I'm building the TopRC F9F Cougar
Old 06-28-2020, 07:51 AM
  #151
vquick
My Feedback: (71)
vquick's Avatar
A lot of problems with some jets on takeoff is the plane incidence it happens a lot on F16 and F18 if the plane have a soft nose spring or incorrect takeoff incidence do plane lower nose they make a hard jump takeoff with the correct plane incidence the plane will have a nice soft takeoff and shorter
Old 07-21-2020, 08:05 AM
  #152
sweetpea01
My Feedback: (10)
I'm almost done with my Cougar. I'm using a 2008 VT-90 (jet central Rabbit, propane start). Old threads say this turbine does 7oz min on avg flight.
I was thinking the fuel tank is too small to give a comfortable timed flight (6-8mins with a 1-2 mins go around). I've seen folks on here use saddle tanks.....any closeups on how you mounted them?
Old 07-22-2020, 06:41 PM
  #153
jetflyr
Here is how I did it.
2 x Sullivan ducted-fan saddle tanks. 16 oz each :-))
Hope this helps.
Greg
Old 09-27-2020, 09:09 AM
  #154
sweetpea01
My Feedback: (10)
Help on the F9 Cougar.
1. Is this where I measure cg from?
2. Is 175mm good for maiden or is there a better number?
3. I'm using a JC Rabbit VT90 (propane start). My Xicoy and finger lift method are showing I need 3lbs in the nose at 175mm. Empty fuel cell, full header, which sits over nose gear. My Batts are 2x 3600 and 1 5000 lipo all in the nose.
Am I in left field here?
