Reload this Page >
Kingtech JMB jets 3m PC-21?
Old 04-22-2019, 10:06 PM
  #76
Neil Guildford
I can’t remember exactly, but know I set mine as per the manual I got which only contained a CG and control throws. I’ll try to find it.
Old 04-23-2019, 02:14 PM
  #77
mstpieree93
A the time of purchase, I had ask JMB about a manuel and he said there wasn't any. And during my last website visit there were no support manuals.
I just sent an email to J-M, asking for the suggested CG.
Old 04-23-2019, 02:51 PM
  #78
ltc
Here is that JM sent me last November
here the setup
PC-21
CG middle of the wing tube
Ailerons 25mm up/down Expo 35%
Elevator 28mm up/down expo 45%
Ruder 30mm left/right Expo 45%
Flaps 2 Positions 15° - 45° Compensation depth on elevator on 15° 2mm and 45° 4-6mm
Tank 1L 6-8min 1,5L 10-12min
brg
Jean-Marc
Old 04-23-2019, 03:39 PM
  #79
mstpieree93
Great! Thanks Itc
Old 04-23-2019, 03:48 PM
  #80
ltc
Great! Thanks Itc
Happy to help
I should mention that the tank and flight times JM referenced were for a K45TP
Old 04-23-2019, 10:03 PM
  #81
Neil Guildford
I am using a Kingtech 60TP with a 2ltr Avanti tank and get 12 minutes, could probably squeeze 15.
I barely use the smoke as it’s not good on the covering.
Old 06-22-2019, 05:27 AM
  #82
mstpieree93
I have finally maiden my PC-21. Wow! What a plane!
The feel of the plane tracking smoothly in the air is truly great. Can't wait to get a 2nd flight done, and many others for that matter.
https://www.youtube.com/watch?v=dbVq...ature=youtu.be
The quality of the video is somewhat weak, but it’s just to provide an idea of how that first flight went.
Old 07-12-2020, 04:39 AM
  #83
Neil Guildford
Does anyone know where I can buy a new nose retract pin from? Its 8mm with a c clip.
Neil
Old 07-12-2020, 07:16 AM
  #84
mstpieree93
Have you reached out to JMB? He did supply me a part relating to the nose gear last fall (had a prop strike - my error, but no damage to the fuselage).
Old 07-12-2020, 10:42 AM
  #85
digitech
My Feedback: (10)
digitech's Avatar
the gear is from JP
call on Shane from jp on Facebook
Old 07-12-2020, 12:13 PM
  #86
Neil Guildford
Thanks for the responses. I think I’ve found something suitable from Electron for 8.50 Euro.
Old 07-14-2020, 05:01 PM
  #87
mstpieree93
Digitech, When you say that the gear is from JP, are you using electic retracts? If so, please share the model/make, as I am considering converting from Air to Electric in the near future.
Old 07-14-2020, 09:29 PM
  #88
digitech
My Feedback: (10)
digitech's Avatar
just contact JP gears , ask for the JMB PC-21 set...
yes its electric
or thru Facebook
Old 07-15-2020, 12:38 AM
  #89
F86_SABRE
Default Pc-21
JP = JPERKINS (the r/c distributor) of UK?
Old 07-15-2020, 02:37 AM
  #90
mstpieree93
Excellent. Thanks guys.
Old 07-15-2020, 11:09 AM
  #91
ltc
IIRC, the same retracts for the Sebart PC-21 XL are/were used in the JMB Jets PC-21
So you could order those (perhaps from Sebart directly) or a set from Pahl Retracts
Pahl Retracts - Online-Shop
Electron ER-40 would be another option as well.
Old 07-15-2020, 12:45 PM
  #92
mstpieree93
These Pahl ones seem to just drop in place. I'll be reviewing these options and see which will work best, For the time being, "let's keep flying"! Thanks everyone
Old 08-12-2020, 01:13 PM
  #93
jdlilfan
Neil Guildford, what pilots and cockpit did you use? Looks good!
Old 08-12-2020, 09:28 PM
  #94
Neil Guildford
I used two vacuumed formed pilots which would normally be sold with a CARF Tucano.
Old 09-04-2020, 04:35 PM
  #95
mstpieree93
Guys, Here's a short video of my PC-21;
Neil Guildford (09-04-2020)
Old 09-06-2020, 06:09 AM
  #96
ltc
Guys, Here's a short video of my PC-21; https://youtu.be/wr6vzoMrudE
congratulations...nice flight
what is your RTF weight?
Old 09-06-2020, 02:50 PM
  #97
mstpieree93
The weight is 31.75Lbs, or 14.88Kg (including 1.75Lb of batteries), and excluding the weight of 2Lts of Diesel, which is about 2Kg more (nearly 4.5Lbs for fuel).
Old 09-07-2020, 01:27 AM
  #98
mstpieree93
I'm curious to see if other owners of K-45TP have similar Run Settings, as I would have liked to get closer to the 170,000 RPMs at max throttle.Even if it were getting up to 165K-168K RPMs.
K-45TP settings:
Full pwr = 160 000 RPM
Idle = 50,000 RPM
Max Temp = 0940°c
Accel Delay = 006
Decel Delay = 008
Stab Delay = 100Pumpt Limit = 0412
Old 09-07-2020, 03:34 AM
  #99
Dansy
My Feedback: (53)
Dansy's Avatar
K-45TP settings:
Idle = 50,000 RPM
Max Temp = 0940°c
Accel Delay = 006
Decel Delay = 008
Each engine are slightly different........and we’re tested at the factory, before shipping....I didn’t change anything on mine and it run great....quite a little power house.
Old 10-23-2020, 09:41 PM
  #100
sebat2b
hello
what is the lenght of the 5 blades spinner
thank you
