Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
Divergent kits
Old 11-28-2019, 11:38 AM
  #51
speedracerntrixie
My Feedback: (29)
speedracerntrixie's Avatar
Bag made from 7mil plastic
Since I have a 4 day weekend, I can get pretty far with the wing sheeting. The method I like to use is vacuum bagging. I truly beleive this is the easiest method and most accurate way to sheet wings. I also feel it is the lightest method. There is no real need to go out and buy expensive equipment. There are a few places such as ACP and CST that offer a little device called EZ Vac. It is a continuous running pump that is inexpensive and works great for sheeting wings. The bagging sleeves and clamps are available from the same sources. I have loaned those items out so I will be using 7mil plastic tarp material and sealing tape for my bag and the same vacuum pump that I use for fuselage production just dialed down a bit.
Old 11-28-2019, 11:42 AM
  #52
speedracerntrixie
My Feedback: (29)
Shuck baseplate made from 1/8" MDF.
Shuck baseplate attached to shucks with double sided tape. The baseplates help distribute even pressure on the cores and help keep everything straight.
Old 11-28-2019, 11:45 AM
  #53
speedracerntrixie
My Feedback: (29)
Match the slot in the core for the wing fence/strut mount in the upper and lower wing sheeting.
Old 11-28-2019, 11:50 AM
  #54
speedracerntrixie
My Feedback: (29)
Check fit to make sure everything lines up.
The stack up that will get placed into the vacuum bag less the 1 mil plastic sheeting that will go between the shuck and wing sheeting. This is a preventative step to make sure the wing does not accidentally get glued to the shucks. Keep in mind that these are the master shucks and will need to be used 4 sheeting cycles.
Old 11-29-2019, 02:36 PM
  #55
speedracerntrixie
My Feedback: (29)
Time to sheet a wing half. Balsa skin prior to epoxy resin.
Wing skin after epoxy application. Each skin got 1/2 oz.
Old 11-29-2019, 02:40 PM
  #56
speedracerntrixie
My Feedback: (29)
Bottom master shuck with 1mil plastic barrier.
Bottom skin placed on shuck adhesive side up.
Core placed on the sheeting, line up the access slot for wing fence.
Old 11-29-2019, 02:46 PM
  #57
speedracerntrixie
My Feedback: (29)
Add the top skin and plastic barrier.
The upper master shuck in place and then lightly tape the assembly together.
Old 11-29-2019, 02:52 PM
  #58
speedracerntrixie
My Feedback: (29)
Two layers of paper towel as breather cloth is taped on top.
The whole stack up is put into the bag and 5 inches of vacuum is pulled. A straight edge is placed on top to verify straightness. The wing will be kept under vacuum for a minimum of 12 hours. I typically like 20 hours better.
Old 11-30-2019, 12:24 PM
  #59
GootyS
Is there any dihedral in your wings when finished?
Old 11-30-2019, 02:01 PM
  #60
speedracerntrixie
My Feedback: (29)
No, both wings are perfectly flat. Coming up soon I will illustrate how I determine that and how I get both wings to have the exact same amount of sweep.
Old 11-30-2019, 02:10 PM
  #61
speedracerntrixie
My Feedback: (29)
The other half of the lower wing made it into the vacuum bag today.
After sliding the upper wings onto the prototype Divergent to verify the roots sit flush with the fuselage, the root ribs were glued into place.
Old 11-30-2019, 02:28 PM
  #62
drac1
drac1's Avatar
So by flat, do you mean flat on top, flat on bottom or flat through the centre line?
Old 11-30-2019, 02:55 PM
  #63
speedracerntrixie
My Feedback: (29)
Flat through the centerline.
Old 11-30-2019, 04:04 PM
  #64
drac1
drac1's Avatar
OK.
Old 12-01-2019, 06:07 AM
  #65
jester_s1
Moderator
I noticed you keep your cores solid instead of honeycombing or some other lightening method. Would you mind explaining why you don't lighten your cores?
Old 12-01-2019, 09:23 AM
  #66
speedracerntrixie
My Feedback: (29)
Jester, these wings are quite thin. The toot thickness is only 1 3/16". It becomes a case of not enough juice for the squeeze. I may at best be able to save 10 grams and then the wings would be too delicate IMO. They would handle flight loads just fine but would have to be handled with a light touch and the honeycomb pattern would be visible on the outter skin. I had one airplane a few years ago with honeycombed wings and hated it. The lower wing panel I just sheeted come out at 4.9 oz. Quite happy with that.
Old 12-03-2019, 05:43 PM
  #67
speedracerntrixie
My Feedback: (29)
Now some fun starts. The next step is to sand the wing sheeting flush with the cores. Cut the slot into the wings for the center brace and join the lower wings together.
Old 12-03-2019, 05:49 PM
  #68
speedracerntrixie
My Feedback: (29)
Joining the lower wing halfs begins with laying the upper wings into the master shucks with the wing tube inserted. The sweep angle is already eastablished in the upper wing, this step gets the master shucks in the correct sweep for the bottom wing.
Tape is placed on the table as alignment marks to duplicate the sweep angle later.
Old 12-03-2019, 05:54 PM
  #69
speedracerntrixie
My Feedback: (29)
The wings are secured to the master shucks with tape, lined up with the tape marks and a 12" slot is drawn out on the wings and cut out on a scroll saw.
The wings were removed and the master shucks were taped together in correct alignment/sweep.
Old 12-03-2019, 05:59 PM
  #70
speedracerntrixie
My Feedback: (29)
Protective plastic sheeting was put down on the center of the master shucks.
Epoxy was spread in the slot and wing roots, the wings were then taped together and to the master shucks. Epoxy was brushed on the wing joiner which is made from 1/8" lite ply and the joiner is slid into place.
Old 12-07-2019, 12:31 PM
  #71
speedracerntrixie
My Feedback: (29)
I'm wondering if anyone has picked up on the mistake I made before joining the wing halves? Serves me right for trying to work on an airplane with a severe cold and whil on cold meds. I forgot to make the channels to run the servo wires. Duh....... the fix is an easy one but it should have been done before. I simply removed a 3/16 wide strip out of the wing sheeting, used a hot peice of music wire to melt away some foam, laid the servo wire into the slot and then filled the slot with 3/16x1/8" balsa. When the Titebond dried I sanded flush.
Old 12-07-2019, 12:32 PM
  #72
speedracerntrixie
My Feedback: (29)
Servo wire slot filled and sanded.
Old 12-07-2019, 12:37 PM
  #73
speedracerntrixie
My Feedback: (29)
Moving onto sheeting the upper wing panels. This requires cutting the master cores down to the same span as the upper wing cores. I'm all set up to proceed with the sheeting/bagging but will hold off a few days. Just this little bit of work with some balsa dust has really aggravated my chest cold and I thought I was going to cough up a lung.
Old 12-14-2019, 04:01 PM
  #74
speedracerntrixie
My Feedback: (29)
Now that I am feeling a bit better I finished up on the wing sheeting and installed the formers in the fuselage shells.
Fuselage shells with formers installed, next step is to seam the shells together.
All wing panels waiting for leading edge and tip blocks
Old 12-18-2019, 12:20 PM
  #75
speedracerntrixie
My Feedback: (29)
Default Wing weights
Left upper wing 126 grams, needs a little more sanding
Right upper wing, 122 grams
Lower wing 290 grams with aileron servo wire.
